It is currently Tue May 21, 2013 7:54 am
 Page 4 of 5 [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Author Message
 Post subject: Re: I want to play with the big kids now too!
PostPosted: Wed Dec 14, 2011 2:48 pm
icantdrift wrote:
PmartyX wrote:
Yea man, all the DE cars flat oilpans.
They were running dry sump systems which use a flat pan since the oil is stored in a tank, the pan is just deep enough for the pump to scavenge the oil. Mucho dinero though for the pan/pump/lines/tank.
Lol no they weren't. They were just running extra oil.
_________________
Offline
 Profile
PostPosted: Wed Dec 14, 2011 4:30 pm
There had to be some kind of sump to keep oil around the pickup or they would've had to keep so much oil in them they would've burned just as much oil as gas and revved slower than hell due to windage. Got any pics? I'm curious how ghetto it was now.
_________________
quazar311 wrote:
Quote:
People go into debt for dumb shit.. this is not dumb.. this is going to be something that you will remember.
Offline
 Profile
PostPosted: Wed Dec 14, 2011 4:53 pm
This... Slightly curious myself... Also curious what they did with the oil filter deal.
_________________
-bump steer makes driving more exciting- (>_<) ヨシ ドリ
Garage Tune LLC - Will try to match or beat ANY PRICE they can
Offline
 Profile
PostPosted: Wed Dec 14, 2011 5:52 pm
Oil filter was in the stock location, with a custom welded aluminum flat pan. There were no dry sump tanks at all.
_________________
Offline
 Profile
PostPosted: Wed Dec 14, 2011 6:02 pm
Interesting.
I will need to relocate the oil filther though because it hits the sway bar with the stock tiny oil filter.
I'm gonna dig into it over the break and see what I can do.
I'm going to try to run a front sump and run lines through the pan for the oil filter. I just need to see how it is set up. I'll pull the oil pan off this weekend if I make it up to Cookeville and start making plans.
I got ahold of a company that can cut header flanges for me and may be able to cut an intake flange if I can't get the stock manifold to do what I need it to.
_________________
Offline
 Profile
PostPosted: Wed Dec 14, 2011 6:04 pm
That's a front sump welded to the stock pan setup. Basically it looks like the rear has been cut off and plate welded in to close it off, then the sump was created in the front and the pickup tube is rewelded to sit down in the new sump.
_________________
quazar311 wrote:
Offline
 Profile
PostPosted: Wed Dec 14, 2011 6:07 pm
Yeah, that's what it looks like and will probably be what I do.
_________________
Offline
 Profile
PostPosted: Sat Dec 17, 2011 8:31 pm
Well my welder and plasma cutter came in! One of the major selling points was that it came it a 110 adapter. When I took them over to the shop my buddy said lets just put in a 220 outlet. So we did. Then we made a giant 220 extension chord.
Sadly we couldn't get gas because the welding place in town is closed on weekends and I'm only here on weekends. So it will be about a week or so before I can get some gas and start messing with the TIG. The plasma cutter is set up ready to go though.
I took the thumb switch of the TIG torch because I don't like them. I prefer the control of the pedal more.
My "Electrician" works for beer
_________________
Offline
 Profile
PostPosted: Thu Jan 05, 2012 3:53 am
Well I did some work today. I had test fit the motor and found that the adapter plate hung too low and hit on my steering rack thus keeping me from lowering the motor and trans in as one unit. This would be a huge PITA. So I had to cut my adapter plate in order to clear the rack. This gave my little plasma cutter a work out but it worked like a charm. Once I got the plate cut, I painted it and put the trans back on the motor and was able to set the motor down in the bay, just about where I need it. Anyhow, here are some pictures:
The adapter plate cut, no worries I wasn't going to use those two holes any how.
The fit:
Almost flush with the trans
In the bay!
Trans tunnel clearance:
Trans
Shifter location, I need to cut that u joint off and 180 it:
Side view, can't even see the motor:
I'm going to try to pick up some material to do the mounts with tomorrow and see where I get.
I am also going to draw up the flange for the oil pan in auto cad and give it to a buddy of mine who says he can get me one cut... would be very convenient!
Getting there... slowly but surely.
_________________
Offline
 Profile
PostPosted: Thu Jan 05, 2012 10:56 am
Good progress man, looking nice!
_________________
Offline
 Profile
PostPosted: Fri Jan 06, 2012 4:57 am
Thanks man. I'm at a stand still until I get an alternator, ps pump and starter to make sure I put the motor in a good spot.
_________________
Offline
 Profile
PostPosted: Tue Jan 17, 2012 1:16 am
So I put a kitchen knife in my thumb the other day... turns out it was a bad idea... So I am currently waiting for this to heal so I can effectively use my left hand again...
Until that happens, I am painstakingly trying to locate the bolt holes of the vk oil pan so I can get a flange cut but it's proving to be a pain in the ass. Getting proper measurements off the pan is a pain. I'm going to work on a solution tomorrow though. We will see how it goes.
Drawing is only for the holes, the lines are there to get the x/y coordinates. They will be deleted once I have the holes in the right spot.
_________________
Offline
 Profile
PostPosted: Tue Jan 17, 2012 10:28 pm
AHHHH! Dat thumb.
_________________
Offline
 Profile
PostPosted: Wed Jan 18, 2012 3:56 am
Yeah, it kinda sucks haha
_________________
Offline
 Profile
PostPosted: Wed Jan 18, 2012 8:22 am
lurky lurk lurk... lurk.
_________________
-Scott :: TRACTION OPTIONAL :: KILLIN 'EM !!POWDERCOATING!!
Offline
 Profile
Who is online
Users browsing this forum: No registered users and 2 guests
Search for:
Jump to:
