It is currently Fri May 24, 2013 8:17 am
View unanswered posts | View active topics
Post subject: Re: 4000 rpms... no more... less is okay... Posted: Sun Mar 28, 2010 11:47 pm |
| OK Finally Past the Hazing |
Joined: Mon Jan 09, 2006 8:31 pm Posts: 1913 Location: marietta
year of car, engine and engine management.
Post subject: Re: 4000 rpms... no more... less is okay... Posted: Mon Mar 29, 2010 11:08 am |
i would look at your tps o2 sensor and knock sensor. and since it s nissan clean your maf to be sure. after you check those sensors it would not be a bad thing to check your fuel psi under load. a fuel up and run a car at low demand but when it is put under a load it fails.
Post subject: Re: 4000 rpms... no more... less is okay... Posted: Wed Mar 31, 2010 2:29 pm |
| Not Really Past the Hazing |
Limp mode is almost always the MAF sensor (or its wiring). DO NOT drive the car long or hard like that and change the oil ASAP. It's dumping so much fuel that it will thin the oil very quickly. 2nd, would be the knock, which is almost impossible to get to, just disconect it to test. Actually, pull the codes, it will tell you what it is.
Post subject: Re: 4000 rpms... no more... less is okay... Posted: Fri Apr 02, 2010 5:26 pm |
| Taco Bar Extraordinaire |
If you havent already since fixing the knock sensor, reset the ECU overnight again. Ive had the ECU show code 55 but still pull timing like a mofo until I reset it.
_________________ siccccckkkkkkkk
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
