Sr20det wiring/ecu
s13driftertb
Sr20det wiring/ecu
Post by s13driftertb »
what wire is the O2 sensor, so I can hook up a air flow meter... I know they are not that accurate, but I have it, and I'm NOT tunnig with it.
or does some one know where to get the service manual for the sr? I checked Zeroyon and I could not find one for the 13.
thanks.
s13driftertb
matts13 wrote:http://www.plxdevices.com/ECUDatabase/N ... _91_95.pdf
ecu pin out info[/url]
DUDE!!!!thanks... I've been looking for this for about an hour...
np
s13driftertb
New Question,
would it make since that my ignitor chip would not be firing in #4 only?
FOERST thing i would check is to see if you have a bad coil. mark coils and switch them around in the motor. if it is still number 4. check to make sure you have power at the coil. then check continuity on the signal wire from the igniter to the coil. if all that is good get back to me and i will give you some more test.
you sir are a gentleman among hoons
P.Haire wrote:you sir are a hoon among hoons
s13driftertb
matts13 wrote:FOERST thing i would check is to see if you have a bad coil. mark coils and switch them around in the motor. if it is still number 4. check to make sure you have power at the coil. then check continuity on the signal wire from the igniter to the coil. if all that is good get back to me and i will give you some more test.
I played the whole switch aroo game in the begining.
(This is the FOERST time I have ever started this engine. I've had it for almost 3 years but was not able to get the funds to put it in)
When I FOERST cranked it up the number 1 and 4 were not firing, I swaped 1 with 2 and 3 with 4 and then cranked her up and one started working along with 2 & 3. I could tell because the new turbo manafold turned gold from crome on 1 thru 3 but 4 hasn't changed much. At the time I got side tracked by a boost leak that turned out to be the #3 o-ring around the fuel injector. Those came in today and I hope to put them in tomorrow.
What would be the easy way to check the continuity? volt meter?
BTW thanks for the help. trying to get her up an drunning for the 24th Nashville event, and I still have to swap over full suspension, stearing rack and brakes.
yeah dvm is your best friend. if it has been sitting that long you could have caroshin on connectors. does not take much to make it happen. unplug the connectors for the coils coil harness and ignitor. make sure the pins are clean and not moving around in the connector. are you using a sr ignitor or a z32?
s13driftertb
Q45 ignitor chip. I got the wiring diagram from HT
I thought the o-rings were going to fix my vac leak but it looks like someone bent my fuel rail. I tried bend it back but still no luck. I'm going to look around and see if I can find one cheap. The only thing is I'm running out of money to dump into this thing. :(
i can send you one for 30 buck if i still have it. think it is my tool box.
i will look around for the wiring of the ignitor you might be a pin off for the coils or something.
whats your email so i can send you a few things.
s13driftertb
matts13 wrote:whats your email so i can send you a few things.
my mommy say snot to give out my personal information on the inter web. because you might molester me :D
but as long as you will hold me after I've p.m.ed my email to you...
i got the fuel rail if you still want it i will bring it home with me so i can ship it out.
