soak them with some kind of lube. they get pretty good and stuck over the years if they're never taken out. take off the top caps and spray some kind of lube to loosen up the orings then pry gently. i broke 3 of mine taking them out even after some lube.
if you have a philliup plus they come out a lot better. that is why i sent you the screws from mine i knew you would have a hard time getting the screws out.
matts13 wrote:if you have a philliup plus they come out a lot better. that is why i sent you the screws from mine i knew you would have a hard time getting the screws out.
