[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4688: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4690: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4691: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4692: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
• View topic - low-mount turbos?
It is currently Fri Jan 22, 2021 10:58 am
 Page 2 of 2 [ 20 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: low-mount turbos?
PostPosted: Thu Oct 29, 2009 3:01 am
I had a bottom mounted td06 on my old sr and it looked like having it that way allowed more space for the mani pipes to be bent at a wider angle. Less drag? some of the mani's I used to see had the pipes all mangled into a big knot. I don't know though.
Offline
 Profile
PostPosted: Thu Oct 29, 2009 4:20 am
im also still running a bottom mount setup. Especially on LHD s-bodys it makes sence to me, with a top mount turbo you need some good heat protection for the brake master cylinder, and how this stuff is called in english lol.
so the temperature situation in the engine bay should be better with a bottom mount. Im also not shure if all top mount kits will fit around the steering on a LHD car - especially with a twin scroll setup its a mega tight fit.
And it doesnt look too spectacular wich makes sense over here when you run the car on the open road. The cops wont notice that a different turbo is underneath :)
Offline
 Profile
PostPosted: Thu Oct 29, 2009 3:10 pm
I thought you couldn't mount an oil fed turbo below 6" above the oil pan because it will cook it unless it has an oil pump? It's what I've heard but I never looked into it. Anyone have anything on this?
Offline
 Profile
PostPosted: Thu Oct 29, 2009 7:52 pm
As far as sr's go I would expect the pressure from the oil pump feeds into the top. Right? I would assume that no matter where you put it, it will still get oil. Mine was pretty low and it never had a problem. I don't know if it meets the less than 6 inch thing though.
Offline
 Profile
PostPosted: Fri Oct 30, 2009 2:45 am
never herad of that tbh.
there should be more than enough pressure to bring the oil everywhere. If you change the tubby on the SR to a ball bearing one you need to put it a very thin restrictor because the oil pressure wuld kill the turbo otherwise.
i´ve got a 3071r on my sr, the only thing i needet to modify was the engine mount. it needet grinding down 1mm to fit the turbo in :)
Offline
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
cron
