[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4688: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4690: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4691: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4692: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
• View topic - Car not heating up.
It is currently Mon Jan 18, 2021 11:21 pm
 Page 1 of 1 [ 13 posts ]
Author Message
 Post subject: Car not heating up.
PostPosted: Sun Jan 03, 2010 11:16 am
Ok this is my wife's s-14 (95) stock and auto transmission.
I dove it for an hour yesterday Highway and surface roads and the temp gauge never climbed above the "C".
The cabin temp never really gets hot either. I checked the coolant level is full.
Could this be a bad thermostat? Or does it need a good flush? I've never had problems with 240's not getting hot,
It's always been too hot and blowing up radiators. :lol:
Thanks,
Offline
 Profile
 Post subject: Re: Car not heating up.
PostPosted: Sun Jan 03, 2010 11:59 am
Stale Meat
heater core clogged up maybe?
Offline
 Profile
PostPosted: Sun Jan 03, 2010 12:52 pm
Is it cold or is it just saying it's cold? Meaning... are you getting good heat in the cabin?
Car running cold is usually low coolant (temp sensor reads cool because of air bubbles), or the thermostat is stuck open. Less likely, but common to 240s... the car is perfectly warm and the system full, but the temp sender has a loose connection. Some of them have the blade for the connector riveted on and it can come loose or the wire develops a break close to the connection due to vibration.
Offline
 Profile
PostPosted: Sun Jan 03, 2010 9:04 pm
I think you are too sexy for it
_________________
Offline
 Profile
PostPosted: Sun Jan 03, 2010 10:43 pm
a tstat stuck open will cause this too.
Offline
 Profile
PostPosted: Sun Jan 03, 2010 11:50 pm
Offline
 Profile
PostPosted: Sun Jan 03, 2010 11:54 pm
Offline
 Profile
PostPosted: Mon Jan 04, 2010 12:12 am
Offline
 Profile
PostPosted: Mon Jan 04, 2010 9:20 pm
Offline
 Profile
PostPosted: Mon Jan 04, 2010 9:27 pm
Oh yeah it was the thermostat.
It was only 20 degrees when I left work so I knocked it out real quick.
Offline
 Profile
PostPosted: Mon Jan 04, 2010 9:43 pm
Offline
 Profile
PostPosted: Mon Jan 04, 2010 10:27 pm
ill be back in nashville in may
:heartbeat:
_________________
Offline
 Profile
PostPosted: Tue Jan 05, 2010 10:59 pm
Offline
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
cron
