It's my brother's daily driver. Just as the WRX Wagon, that he sold not that long ago, this car has seen nothing but the best possible care and he has the appropriate stack of receips to prove that (ALL of the fuel bills are on hand, 57 of them).
It has been in our possession since it had ~119xxx miles on it and when it hit ~128849 it got refreshed to this current state. The car has being daily driven and proven in this setup for the last ~3500 miles non-stop in any weather (since January), averaging 27-28 MPG along the way.
Condition: Soft top has been changed, it does not leak at all. Carpets were out and cleaned. A previous owner was a lady, she drove with heels, so there is a small hole under the gas pedal from them. Also in her ownership the car was dented on the rear passenger side and repaired, but it is still noticeable (see 3rd picture). It has been straightened up before i get it, but it's still noticeable. There is also a small hole in the passenger taillight.
Brand new OEM brake rotors and pads will be included in the sale.
*** Note:
- The car is now on stock suspension, as seen in the 3rd picture.
- The car is not cleaned in any of the pictures.
- The wheels are 15x8 +0 and are coming with the car.
- The car will come with stock steering wheel (w/ airbag) and stock (weighted) shifter knob.
- The valve cover is NOT that shiny in person.
*** for reference
1.8 Mazda NA8 Miata
132644 miles
- 5 speed manual
- driver and passenger airbags
- with A/C and P/S
Engine:
- NEW genuine Mazda water pump w/ gasket
- NEW genuine Mazda timing belt, idler and tensioner pulleys
- NEW genuine Mazda front main seal
- NEW genuine Mazda valve-cover gasket
- NEW genuine Mazda 192°F Thermostat
- NEW genuine Mazda PCV valve and grommet
- NEW Mishimoto radiator
- NEW hoses (here and there)
- NEW NGK Iridium spark plugs
- NEW NGK ignition wires
- NEW (lightened) FujiRacing Crank Underdrive Pulley with PS/AC
- NEW belts PS & AC, water pump & alternator
- NEW fuel filter
- ONLY Mobil1 oil and oil filters as well as genuine Mazda oil filters used in the car
Drivetrain and Chasis:
- NEW Tokico clutch master cylinder
- NEW Tokico clutch slave cylinder
- NEW genuine Mazda shifter boot (small)
- NEW genuine Mazda shifter boot (large)
- OEM exhaust repaired for leaks
Miscellaneous:
- shaved finish panel in black
- replaced soft top (great condition, no leaks!)
***Other related items for sale:
- shaved finish panel - $100
- fiberglass soundbox w/ 2 subs - $200
- tonneau cover - $100
Asking price is $4500 OBO
text/call 314-503-4340
FS: STL '96 Miata
Re: FS: STL '96 Miata
updated
