fuel swirl tank made by Peterson Fluid Systems. Keeps you from starving your engine of fuel by keeping a reserve that won't slosh away from the pump like fuel inside the stock tank. Requires a second pump to feed from the swirl tank to the engine, you can feed the tank with your stock pump. Has 3 -6an ports; one for feed from the stock tank, one for a feed from the stock return line, and one for overflow back to the stock tank return. Feed port is a -10an and i have a -10 to -8 adapter that will come with it. T-bolt mounting bracket with added silicone coupler used as a jacket to minimize vibration. On a reasonably high HP car needing lots of fuel flow this will give you 30-45seconds of continuous protection against starvation if your in-tank pump runs dry.
Crackhead price of $100.
Fuel swirl tank
Re: Fuel swirl tank
tyler.
