[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4688: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4690: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4691: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4692: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3823)
• View topic - My car is fo sell
It is currently Fri May 14, 2021 10:05 am
 Page 1 of 1 [ 12 posts ]
Author Message
 Post subject: My car is fo sell
PostPosted: Fri Jan 13, 2012 11:43 am
In case someone wants to buy it :D Would also appreciate a repost on Ziptied if someone wouldnt mind, and letting them know to email me all their hate instead of posting it in the thread since I won't be able to see it otherwise.
Price is $7500 pretty firm. Best way to reach me is email: jsquareddddd@gmail.com Also looking for 4wd truck trades +cash, Ford Rangers (4.0 v6 only) and Toyota pickups (22re only). NO SUV's, need to have a bed.
230k miles
S13 SR20DET swap
Stock turbo
Stock ECU
Stock fuel
3" exhaust with test pipe and highflow cat (built by TopSpeed)
4" midmount FMIC
Mishimoto radiator with dual shrouded fans
Electrnic fan controller
HKS pod filter
CS catch can
Steel braided fuel lines
Steel braided power steering lines with AN fittings and custom reservoir
Optima redtop relocated to rear bin
PASSES EMISSIONS EASILY. It is tested as a rotary-powered RX7, afterall.
17x9 +22 and 17x9.5 +12 Volk TE37's
Federal supersteels on the rear (almost new), worn Toyos on the front
Tokico blue struts (new)
Tein S-tech springs (new)
Supernow outer tie rods
Secret Element inner tie rods (lots of angle)
50-50 weight distribution without corner weighting. Car weighs 2777 pounds fully wet.
Also have stock wheels, will take $1000 off if you don't want the Volks.
Legit car, legit build, not half assed. All cluster gauges except the boost gauge work like OEM (tach, speedo, fuel, temp, etc). Wiring is professional and NOTHING is hardwired. Cold start signal works, rev limiter works, emergency fuel cut works. It runs and acts like a stock SR in a stock FC.
Car has a few issues, most are pretty typical of FC RX7's. Wipers only work on the medium setting, rear wiper doesnt work, some of the plastics in the dash (vents, trim, etc) are cracked/missing, driver window sticks a bit and needs to be lubed, sunroof sticks a bit but gets going with a nudge, passenger door handle needs to be replaced (I have one ready to install), front wheel bearings are close to needing to be replaced (have extra front spindles with good bearings), sometimes the throwout bearing squeaks when the clutch is out. Minor stuff for the most part. This is a solid build on a chassis with 230k miles, so dont expect it to be showroom ready. Paint is OK, mostly presentable but the hood has flaking in the clearcoat and needs to be refinished. Also, no AC and no heat. Heater lines are looped but the blower motor still works for defrost, and AC is completely out of the picture. It has a radio but I dont know if the speakers are working or even hooked up. Radio gets power but no sound, and 6 disc changer has power.
Let me know if you want any of the hundreds of pics of the build I have, or more info on anything. I built this car, I know it top to bottom.
_________________
Offline
 Profile
 Post subject: Re: My car is fo sell
PostPosted: Sat Jan 14, 2012 12:00 am
Please at least keep that steering wheel!
_________________
Offline
 Profile
PostPosted: Mon Jan 23, 2012 5:36 am
mmm fc haz correct mortar
_________________
-Scott :: ::
Offline
 Profile
PostPosted: Fri Feb 10, 2012 11:36 am
$6500 cash. need this shit gone.
2% in your pocket if you find a buyer!!
_________________
Offline
 Profile
PostPosted: Fri Feb 10, 2012 11:50 am
I'll post it on the s3 fb page, that'll get a few thousand people looking. Maybe it'll help!
_________________
Offline
 Profile
PostPosted: Fri Feb 10, 2012 12:00 pm
Thatd be awesome, thanks buddy! More pics here:
http://smg.photobucket.com/albums/v206/ ... or%20Sale/
_________________
Offline
 Profile
PostPosted: Fri Feb 10, 2012 1:07 pm
No problem! Got it up there now, hope it does some good!
_________________
Offline
 Profile
PostPosted: Sun Feb 19, 2012 2:50 pm
Such a good deal! GLWS!
Offline
 Profile
PostPosted: Tue Feb 21, 2012 2:31 pm
Thanks man! REALLY need to sell this soon, picking up a truck on Friday and I can't have three and a half cars. Well I could, but my better half would balk and pout. Cant have that.
_________________
Offline
 Profile
PostPosted: Thu Mar 01, 2012 10:29 pm
Sold
_________________
Offline
 Profile
PostPosted: Fri Mar 02, 2012 12:17 am
Bittersweet
_________________
Offline
 Profile
PostPosted: Fri Mar 02, 2012 8:59 am
Def, once the truck is together I will feel better about it im sure.
_________________
Offline
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
cron
