i've decided to simplify things and run an in-tank surge/collector, so i'd like to get this stuff gone to be able to pick one of those up for the new cell. as usual this stuff is pretty crackhead priced for obo for fam.
Summit 15 gallon aluminum cell with two -8AN pickups, -8AN return, -8AN Vent with internal rollover valve. Tabs have been cut off since straps are the only proper way to mount these things, otherwise unchanged and unused. aircraft sytle flush mounted cap. 0-90ohm sender installed.
looks like this with the tabs removed.
retails for $249 from summit, asking $150.
Aluminum fuel swirl pot made by "Peterson Fluid Systems". round swirl pot with -6AN inlet from pump, -6AN inlet from return, -6AN overflow, -10AN feed on bottom for main pump. i'll also include a -10AN to -8AN adapter, two -6AN 90* fittings, one -6AN 180* fitting, and an -8AN 90* as well as a couple feet of -6 and -8 push lock hose to help plumb it all. has t-bolt clamp mounting. this thing will ensure you can run your tank pretty much dry and never have fuel starvation issues.
$175 w/fittings and hose or $140 for just the tank.
some fittings in photo not included.
140GPH low pressure ProComp fuel pump. comes with either 5/16 or 3/8 hose barb connections (can't remember at the moment) and i'll also include a -8 inlet fitting and -6 outlet fitting. would go great with the cell and swirl pot as a scavenge pump. actual pictures will be up later $40
RFL knockoff BOV. comes with steel/aluminum flanges and spacers for adjustment. never used. $30
Fuel Cell/Swirl Pot setups
- icantdrift
- down_shift
Re: Fuel Cell/Swirl Pot setups
i am in for the lp pump for sure. might want some of the other shit.
- icantdrift
updated.
Matt, would the swirl-pot be good for my car since it gets fuel-cut crazy sometimes? Or should I replace that suck-pump and bypass the swirly-whirl?
um yes that is the cure for that problem. would be a little tricky to put on your car. would have to look at way all fitting your would need. also you would need that external walbro pump too.
- icantdrift
updated with more stuff
I might be down for the bov since mine is already crapping out. I could use a swirl pot and FP but don't have the cash ATM.
