Upgrade!
Re: Upgrade!
collink wrote:I guess the fact that I want to do something more unique isn't a good enough argument?
heeeeeeeeeeeeeeeeeeeeeeeeere we go again.... :roll:
collink
Re: Upgrade!
Post by collink »
how is it unique?
it's been done before...
I said "more unique". More unique than a M42 TI...
Re: Upgrade!
Just do what you want, mang. Dont listen to these newbs.
Re: Upgrade!
there's no such thing as "more unique"
Re: Upgrade!
charlie, you kill me dude. awesome.
bradt
Re: Upgrade!
Post by bradt »
+1 for the E36. You won't look back.
Personae non Gratae.
Re: Upgrade!
Ya man, you may think that it's being unique, but really, you would be way better off for drifting if you just put that thing back together and sell it to get a factory M3. The ///M that I drifted for like a year and a half was pretty tossed together and it ripped.
Re: Upgrade!
youll spend more trying to swap the car then if you had just bought a m3. trust me im doing a na to turbo swap and still havent finished it yet because of wiring and thats something that came factory.
Re: Upgrade!
XP
collink
Re: Upgrade!
Post by collink »
Pulled the head tonight. Head gasket was completely fine. Obviously, I couldn't check compression with the head off, but cupping my hand over the cylinders produced both vacuum and pressure (not that I'm suggesting that this is a means of gauging compression...just noting that the rings seem to be doing their job still). There were also no chips in either the pistons or the valves that I could see. At this point, I have no idea what's wrong with it. My only guess is a bent valve...
Any suggestions?
Re: Upgrade!
oh shush eugene lol. im sending over to someone to get it done finally. if it dosent work, just dumping the engine and getting a 1j
Re: Upgrade!
Post by mikespeed95 »
"hey why did you rear end GRENADE like a mike peters ls1?"
"because its a 318, im unique!"
"why did xxx break and you cant use e36 parts, you have an e36??"
"why is silly stuff breaking in your drivetrain/chassis"
"you spent how much and why?!"
wanna be unique/cool? get past the skill level of working on a bmw without torx sockets (HF doesnt count, craftsman isnt much better) and do something actually different. build a z3 with a 2j.
ooooooooooooooooooooor
do something cool and unique to drifting, order a euro m3. prolly cost the same as the mix match youll end up with, and youll save a lotta time. the time is money (t=m) equation is always true so just do that.
not trying to be mean but this thread could easily go down facepalm avenue, and thats just no fun at all.
Re: Upgrade!
Where's that helmet...
Ah, here it is.
Re: Upgrade!
collink wrote:Pulled the head tonight. Head gasket was completely fine. Obviously, I couldn't check compression with the head off, but cupping my hand over the cylinders produced both vacuum and pressure (not that I'm suggesting that this is a means of gauging compression...just noting that the rings seem to be doing their job still). There were also no chips in either the pistons or the valves that I could see. At this point, I have no idea what's wrong with it. My only guess is a bent valve...
Any suggestions?
5 psi will suck your hand in... so that's not a measure.
You said you had oil/coolant mix.. figure out what caused that FOERST. Take a closer look at the headgasket.. any nicks/chips can cause a headgasket failure.
You can look to see if you have a bent valve. Was your timing off before you took the head off?
Did you over-rev the motor?
collink
Re: Upgrade!
Post by collink »
quazar311 wrote:5 psi will suck your hand in... so that's not a measure.
Only reason I mentioned this is because the mechanic at the BMW shop I sent it to said one of my cylinders had literally ZERO compression.
quazar311 wrote:You said you had oil/coolant mix.. figure out what caused that FOERST. Take a closer look at the headgasket.. any nicks/chips can cause a headgasket failure.
After doing some more research, I'm not so sure it was oil/cooland mixed. It was like a really dark green color, and it smelled TERRIBLE, but there was no coolant in the oil last night, and I never saw like creamy, latte looking substance like I've seen in so many instances in my research online. Does it still sound like an oil/coolant mixture?
quazar311 wrote:You can look to see if you have a bent valve. Was your timing off before you took the head off?
Upper timing chain was on time when I pulled it. Haven't pulled the lower timing cover to check that it's on time.
quazar311 wrote:Did you over-rev the motor?
It hasn't been over-revved since I've owned it, no. I can't speak for previous owners. I mean someone put a Dinan TB on it, so it's probably that someone beat on it at some point.
