if hinson sent the shit to mount your motor with no promised wiring harness and other necessities to do a swap 48 hours before you needed to leave before long beach then your car woudl probably be pretty jank too.
cant wait to rip it apart and start over after PRI though.
run a 0 gauge wire directly from the battery to the alternator, and also upgrade all the grounds.. get one of those cheap ground block kits off egay. They do work. Yea, power is def down on that.. my Lexus on low boost is making over 340lb/ft
