My car died on the road, help needed.
- EVOsaiyanPrince
So yesterday I drove up to the gas station to try and work on my car, I hop in, try starting it the same way (pumping the gas a little) and it fires right up as expected. There was a little bit of smoke as I started it and it was white and it smelled just like gas. I decided to see if it would idle, so I took my foot off the gas, and there it was, idling at 1k, just like it always does. No smoke, no fluids leaking, no nothing. So I decided to try my luck and drive it home (about 2 miles), and it gets there no problem. So now it's sitting in my driveway until I can figure out what the problem is. On my next stretch of days off I'll be doing a lot of figuring out.
The worst part was walking that 2 miles back to the gas station to get my girlfriends car that I drove there in the FOERST place....
if the white smoke smells like gas like you say it does then your head gasket should be fine. FOERST things FOERST, a simple can of seafoam (takes moisture out of the gas tank/lines) in the gas tank and a fuel filter is the cheepest easiest thing to do. If it continues to smoke pull your plugs if they are black and covered in carbon build up just replace them. You can also check your wires make sure they are firing if not check the rotar button cap etc... Thats all the basics if that doesnt do it guess we'll be back at square one. lol
1991 nissan 240sx
-1995 nissan pathfinder
