bought some ATF3 put 2 liters in, gearbox works like new, the "giver" sayd it was overhauled just befor he unregistered the car... Generator doesnt load properly but i will get it to work, will drive some meters 2morrow :-)
bike verions 2.25.jpg (738.04 KiB) Viewed 784 times
2.5 as soon as i figure out how to cut my chain off.
never going to find grips that match my pedals.
You can get a chain removal tool at Wally World for $5ish bux.
yeah, or i could wait till my roommate gets home and i can use his hack saw.
P.Haire wrote: never going to find grips that match my pedals.
Oh no?
Treefish wrote:â™  Byronial New Headlights & D-Max Clear Corners â™
got my car registered in Brazil.
its hard to remember this
Ooh, looks dreamy with the new lights!
The song protruding from my pants right now is definitely BONE THUGZ IN HARMONY.
andysapp wrote:The song protruding from my pants right now is definitely BONE TUGZ IN HARMONY.
you sound like a homo roadie, can I get a helmet to match my shoes and tires?
Oh no?
this is the second set of "purple" grips that i've ordered and they keep showing up fuchsia-y. the old pair got really pink after a couple days in the sun.
car is looking really good byron!
Finally Byron! Looks awesome. Now you need LED tails.
Also Patrick the purple Oury grips are pretty purple. I think shawn has a pair on his bike and they aren't Fucia-y
http://www.benscycle.net/index.php?main ... bf4d74dac7" onclick="window.open(this.href);return false;
(non-BMX version on Shawns)
byron, that is looking good! I been meaning to buy the new light covers for a while now but figured i need to get the car running before getting the light covers. was it easy to cut off and put the new one on?
well because I didn't really do any research for write ups before starting I wasn't sure how they were assembled. I thought the factory lenses were constructed like the replacement ones. the factory lenses sit inside a channel filled with sealant while the replacements sit flush on top of the channel. you dont need to pry them at all. what worked best for alex and I was to pop off the clips, then heat the seam/joint all the way around with a heat gun for several minutes until the plastic is hot (wear thick gloves) to the touch then just pull them apart. avoid tools because the plastic is super melty. The seal is really tight so it takes a good bit of convincing. a razor is handy to cut through the mozzarella sealant as you pull them apart. then its just a matter of resealing them with a thick line of RTV and tapping them up to dry for a couple hours.
^ i know exactly what youre talking about.....i had to do the same thing with maxima tail lights. cool deal! I want to do that so bad!
