Free Drifting at Lanier Speedway: Exhibition
body kits and over fenders and gt wings?
glad it's nothing too bad.
just tore the car apart... it's going to be a bitch to straighten :(. the strut tower is pushed over along with that whole side of the chassis a good bit. the strut tower is touching the brake master cylinder it's moved so much.
the minor parts needed are new tierod ends, a swaybar endlink, left lower control arm, and TC rod. i'll have to fix the headlight tabs as they are smashed pretty bad. the back lip of the wheel is bent where it was pushed into the coilover but not too bad. both wheels on that side are scuffed on the outer lips pretty good. rear fender will need to be re-rolled since it pushed in the lip.
:shock:
That sucks so bad.
Any parts you need that you don't have? I can see if dad has any in our storage bins.
sucks man. hope you can get her straight again. that cars been through a lot. holler if you need anything.
matt is going to hook up the LCA and spindle. if you guys have a stock endlink for the swaybar i could use one. the TC rod and rod ends i'll have to source.
new super max angle front control arms
and what i believe actually caused the destruction
icantdrift wrote:matt is going to hook up the LCA and spindle. if you guys have a stock endlink for the swaybar i could use one. the TC rod and rod ends i'll have to source.
I will check on that for ya.
that sucks :(
good luck with the fixing though, and let me know if there's anything i can do to help!
Inappropriate Chris
Past the Hazing
Post by Inappropriate Chris »
Worse case scenario if you do not have the parts in time, I have spl inner and outter tie rod ends and spl tension rods and stock end links for sway bar if you need them to be ready for November. Just let me know.
metalmulishaS13 wrote:Worse case scenario if you do not have the parts in time, I have spl inner and outter tie rod ends and spl tension rods and stock end links for sway bar if you need them to be ready for November. Just let me know.
your damn car better be ready for november, or i will come finish it for you and drive it in front of you while giggling like a schoolgirl.
Maaaan... I liked the idea that it wasn't that bad.
I'm hella bummed right now.
I don't like seeing pictures of my friends car in pieces on the floor.
Let me know if you need any help turning wrenches or blaring metal.
Inappropriate Chris
Past the Hazing
I have already said I wont be in the state for November, I am already bummed that I will be missing it. So if I can't make it and those pieces are what stops you from making it. You can have/use them or whatever.
we are your only family son!
Inappropriate Chris
Past the Hazing
Ahhhhh, thanks Matthew. But Im still going. Sorries.
