Posts: 5987 Joined: Fri Sep 03, 2004 1:03 pm
by icantdrift » Fri Jan 09, 2009 6:50 pm
Maudite wrote: working on it, I don't want to bottom out the strut and ruin them like ruined the others.
they are height adjustable, no more excuses. drop them in the mounts until the housings touch the axles.
Posts: 11575 Joined: Tue Jan 24, 2006 8:05 pm
by Greg » Fri Jan 09, 2009 6:53 pm
you mean the lower mount? turn the mount upwards? these are my FOERST hella adjustable coilovers.
Posts: 6964 Joined: Mon Feb 07, 2005 12:14 am
by shawn shawn » Fri Jan 09, 2009 9:52 pm
Maudite wrote: you mean the lower mount? turn the mount upwards? these are my FOERST hella adjustable coilovers.
Don't touch the 2 collars under the spring (that adjusts preload not height). Loosen the collar at the bracket holding it on and turn the entire shock to lower. Top is pillow mount so the whole thing will spin w/o unbolting. That way shock has the same travel and you can go low low.
_team rowdy _
by icantdrift » Fri Jan 09, 2009 10:07 pm
what shawnshawn said. loosen the spanner nut that locks the lower mount in place, thread those bad boys down until desired height is reached. the one thing to watch out for on the subie is that you don't go too far and the bottom of the shock casing hits the axle. other than that crank the top parts back up so you maintain full shock travel and proper preload. you do want to try to even out preload, so measure the distances between everything when adjusting to at least keep it even on both sides. the only right way to set preload is corner weighting, but for a DD it's not important.
see red arrow
by Greg » Fri Jan 09, 2009 10:40 pm
ah gotcha, thanks bros
Posts: 7666 Joined: Wed Jul 28, 2004 6:00 pm
by revel » Fri Jan 09, 2009 10:53 pm
thats it i wanna put stances on the GC
Posts: 14403 Joined: Mon Sep 27, 2004 8:13 pm
by P.Haire » Fri Jan 09, 2009 11:08 pm
whatchu got on there now?
by revel » Sat Jan 10, 2009 3:11 am
cusco zero2Rs
by revel » Sun Jan 11, 2009 10:18 pm
now with brake lines:
mmmmmmmmmmm:
more mmmmmmmm:
by P.Haire » Sun Jan 11, 2009 10:28 pm
what's the deal with the wires?
looks good otherwise.
by shawn shawn » Sun Jan 11, 2009 10:36 pm
Won't your relays get soaked on rainy day events right there?
_team rowdy _
Posts: 1925 Joined: Mon Jan 09, 2006 8:31 pm
by matts13 » Sun Jan 11, 2009 11:34 pm
thoes are weather prof relays and are for the head lights. all the other fuse are where the glove box goes.
by shawn shawn » Sun Jan 11, 2009 11:38 pm
Cool beans!!!
Lookin' clean clean clean!
_team rowdy _
by matts13 » Sun Jan 11, 2009 11:44 pm
its almost to clean. and i am putting way to much time into it. it looks good but it is just going to hurt that much more when i fuck it up.
by P.Haire » Sun Jan 11, 2009 11:59 pm
it's just practice for your next racecar. keep going!
