i have no way of checking that.collink wrote:Have you tried a compression test? Just sounds a little familar. Cooling issues, then the car not starting and whatnot.VRT nenders wrote:going to try and replace the fuel pump relay and see if that helps.
in other news i have to have this car out of here running or not by next week cause i have to move.
The same thing happened to me, and it was compression (thought I'm still not sure where I was losing it). Dunno if that helps or if you've checked it. Just a thought though.
WTH (want to hire): BMW mechanical help.
- VRT nenders
- Taco Bar Extraordinaire
Re: WTH (want to hire): BMW mechanical help.
- VRT nenders
yeah long story short, the condo got foreclosed so i have to grab my shit and get the F out.revel wrote:you moving again?!?!?!?!?!?!VRT nenders wrote:going to try and replace the fuel pump relay and see if that helps.
- collink
- OK Finally Past the Hazing
I think AutoZone rents compression test kits.VRT nenders wrote:i have no way of checking that.collink wrote:Have you tried a compression test? Just sounds a little familar. Cooling issues, then the car not starting and whatnot.VRT nenders wrote:going to try and replace the fuel pump relay and see if that helps.
VRT nenders wrote:yeah long story short, the condo got foreclosed so i have to grab my shit and get the F out.revel wrote:you moving again?!?!?!?!?!?!VRT nenders wrote:going to try and replace the fuel pump relay and see if that helps.
FUUUUUUUUUUUU...
