gremlins
skylinesx
gremlins
Post by skylinesx »
was wondering if anyone elses car's have done this.
after the dg trials yesterday my tail and brake lights were staying on constantly only way i shut them off was when i unplugged them. I unplugged the brake light switch and unplugged the fuses to the brake light and tail lights and they stayed on. only thing i could figure was a short to ground on brake lights and the tails were shorted to the power side on the brakes. Also my ignition would not shut off, and the fuel pump continuously primed, last time the FP primed constantly the eccs relay was messed up. Even when i unplugged the ignition lock cylinder it stayed on?
1991 nissan 240sx
-1995 nissan pathfinder
skylinesx
Post by skylinesx »
hmmmm anyone :?: :?: :?
1991 nissan 240sx
sound like a short in the chassis harness.
in my civic the bracket on the brake pedal that actually pushed the button for the brake lights broke.
honestly the best advice i can give you is talk to carter.
collink
Post by collink »
A friend of mine was having this problem and he theorized that the button that the bracket pushes on the pedal assembly was sticking...you might check that when you check the button...
skylinesx
Post by skylinesx »
alright i'll double check the brake light switch, other then that figured i'd pull the majority of the chasis harness and start lookin around it with the multimeter see if i can find any shorts.
1991 nissan 240sx
s13driftertb
Post by s13driftertb »
would it be the harness under the fron wheel fender?
has that been tucked up on your car, because you car sits pretty low.
skylinesx
Post by skylinesx »
you know I never even thought about that, through a couple of runs i had some pretty serious understeer, and i went off track twice, could have put a tire into the wiring and caused some problems. Thanks i'll check that out for sure. Although on the ignition side i'm not sure if any of that wiring goes into the fender weel or not though. If I can get on mitchell here at school i'll see if I can print out any entire wiring diagram for the brake lights and ignition.
1991 nissan 240sx
i don't think brake lights run to the front of the car.
i actually saw that and asked alan about it.....he said that s13s had a problem with the button on the pedal where the rubber piece falls off or something. its something with the pedal....check that out
s13driftertb
P.Haire wrote:i don't think brake lights run to the front of the car.
well they could...
no I was thinking with the fuses and relays up there?
I’m just throwing out ideas I hate wires (with a vengeance!)
skylinesx
Post by skylinesx »
talking to a few people and they said on some cars the front side markers are tied into the tail lights and possibly smashed some wires, but i will also double check the brake light switch.
1991 nissan 240sx
s13driftertb
s13driftertb wrote:would it be the harness under the fron wheel fender?
:wink: :lol: :lol: :lol: quietly pats self on the back. :lol: :lol:
no you didn't you posted something on the internet.
s13driftertb
P.Haire wrote:no you didn't you posted something on the internet.
lolzzzzzzzzz
skylinesx
Post by skylinesx »
found the problem, thanks for the input guys.. :D
1991 nissan 240sx
