broken open diff..
Korey
broken open diff..
Post by Korey »
..So my car is on jack stands, and I thought it was something to do with the tranny. I replace the tranny with another and new slave and all that jazz and attempt to drive my car. However the driveshaft just spins, so then I take off the back case cover on my open diff and find a broken gear, both halves of it are laying inside. My question's to ya'll are:
Is sliding in an open diff (or trying too..) harder on the diff than if you were using a limited slip?
Does anyone have a writeup on welding a diff?
What does it mean when people say they have 25% lockup, someone told me quite a bit about lockup awhile back, but I forgotten. :(
How many people are using:
-Welded diff's
-After market diff's
or....
-oem LSD's?
Thanks in advance!
Korey
Korey
Post by Korey »
Help??
most of the people on here have 1.5 or 2 way clutch pack diffs. a few have welded waiting to change to clutch packs.
Go for a KAAZ all the way.
Worth every cent, and then some.
Korey
Post by Korey »
Kaaz just makes a 1.5 way for BMW's, is that any better or worse for drifting?
DrifterMama
Post by DrifterMama »
http://auto.howstuffworks.com/differential.htm
http://en.wikipedia.org/wiki/Limited_slip_differential
These explains the difference between 1.5 and 2 way LSDs that will give you a better understanding of what they do so you'll understand what's what etc...
\\Amanda//
Korey
Post by Korey »
'Preciate it!!
Welded diffs have any other downfall besides breaking them?
tire wear
noises (from tires chassis etc)
considered "harsh"
i <3 my kaaz 2 way.
I do just fine with the 1.5way. Only time I ever notice it is if I come in too hot, and have to jab the brakes real quick... and even then - it's noticed minimally. Plus, I'm pretty sure you could talk to Ray at KAAZ and see about a 2-way.
Korey
Post by Korey »
1300 for the LSD right? Thats not a whole case, just the internals??
DrifterMama
^^ yep
\\Amanda//
Korey wrote:1300 for the LSD right? Thats not a whole case, just the internals??
ProjctGrlDrftr wrote:^^ yep
huh what diff is that for bmw?
Yeah... $1300 was for my 1.5way for the e46.
That is just for the limited slip unit. Best avenue to take, is get a replacement pumpkin off car-part.com, so you can have little-to-no downtime. Just swap pumpkins, and rock out.
Korey
Post by Korey »
...soo you just get the internals? You think if I called him up this summer he could hook me up with a 2-way instead of a 1.5 way?
Also, should I do a Jstock suspension setup FOERST, or a 2 way? both are very important, but which one would help me the most??
