Update on Project B *Pics, 56k beware* *NEW PICS*
Kouki7
Post by Kouki7 »
well i got the motor pulled last thursday and i'm taking it to Mazda on Monday to order my new Reman Motor. so right now i'm at about 50% on my new motor project that i have named Project B.
i spent about 3 hours today porting my wastegate so that i won't be spiking to 15psi like i was before. i'll have some pics up if photo bucket will let me upload the pics and host em.
EDIT:
i have the pics uploaded now so i'm gonna post em if it'll let me...
225rwhp on 9psi
Kouki7
Post by Kouki7 »
cool its working, here's the rest....
motor about to be stripped...
shot of the ACT HD Pressure Plate and 6 puck clutch kit still on the car...
stripped down....
my pile-o-parts...
compressor side of my stock Hitachi HT-18...
4 upper holes are the intake ports, the 2 lower holes are the exhaust ports...
look! its naked!!! OMG...
225rwhp on 9psi
Kouki7
Post by Kouki7 »
now here's the pics of the porting i did today on the wastegate....
the right hole used to be half the size of the left hole...
a little better shot to see how much i've done...
this is what you'd see if you were the exhaust coming out of the motor...
kinda like that last one..
225rwhp on 9psi
cool pics!
and strippied rotaries sure look crazy!
Kouki7
Post by Kouki7 »
thanks man. rotary engines are tiny when they're stripped to bare block. :)
i'll get some pics of the empty engine bay later once i clean it out some.
225rwhp on 9psi
djdorifto
Post by djdorifto »
no wonder them engines get super cooked lol. I took out a engine out of my friend's FD ones, pretty amazing how small they are when you start to strip them down. awesome pics bro!
Kouki7
Post by Kouki7 »
thanks. i'll keep porting more as i progress with this.
when i get my new engine i'll get some pre-assembly pics of it for ya. :D
225rwhp on 9psi
turbofb
Post by turbofb »
they look like a beer keg stripped down, how much did you get the reman for?? If it don't run right it might be a bad motor, i've seen several remans blown up from the start :?. How much boost are you going to run? What year are going to get, the later years(s5) have more compression ratio.
Kouki7
Post by Kouki7 »
turbofb wrote:they look like a beer keg stripped down, how much did you get the reman for?? If it don't run right it might be a bad motor, i've seen several remans blown up from the start :?. How much boost are you going to run? What year are going to get, the later years(s5) have more compression ratio.
wow, lots of questions for me here. :)
here we go...
- i'm getting the reman for $2250.
- if it doesn't run right i take it back to Mazda and they give me another one free. they're giving me a 1 year unlimited mileage warranty with this motor even with me doing all the work myself.
- after break-in i'm going to run 8psi on the low setting and my high setting will be 12-14 (haven't decided yet).
- i'm going to order an S5 motor since thats what i have. S4 won't run in my car with the wiring harness and ECU i have. i am also aware of the higher compression of the S5 motors.
hmm, what else.... oh yeah! don't worry about my fuel system, i have it taken care of for the stock turbo and stock port motor. i have an HKS F-Con and freshly cleaned injectors from RC Engineering. anything else you want to know feel free to ask. :D
EDIT: for boost controll i have a Blitz Dual Stage Boost Controller.
225rwhp on 9psi
wow those are awesome photos! that's my FOERST time seeing a rotary opened up like that-- very cooL!
Kouki7
Post by Kouki7 »
really nobody? well in that case i'm glad i could give you a new experience. :D
in short block form they don't weight more then probably about 180lbs.
225rwhp on 9psi
turbofb
Post by turbofb »
High compression is the only way to go, have 9.4:1 rotors, same with the other one you saw. have fun w/ that puck clutch, that sounds like alot of fun on the street :shock: . 2250 isn't to bad, i just don't trust mazda remans.
Kouki7
Post by Kouki7 »
i've already ran about 800miles on that clutch combo. i had a 91 TII motor in the car but it blew (weak front apex seal). thats why i'm putting a new motor in. the HD pressure plate and 6 puck disc isn't to bad, it just takes some getting used to. it sure does grab like a vice though! its just about unslippable.
225rwhp on 9psi
turbofb
Post by turbofb »
I'm putting in a act hd psi plate, and organic street disc tomorrow. Its a full disc w/ sprung hub. Same clutch my friends car has, seems to handle 380whp, so my setup shouldn't phase it a bit.
Kouki7
Post by Kouki7 »
sounds good man, my 6 puck disc is UN-sprung.
225rwhp on 9psi
