Bad Thermostat?
collink
Bad Thermostat?
Post by collink »
How do you tell if your thermostat is bad? I went out drifting last night with some friends and my S14 was overheating like CRAZY. I just put a new water pump and 16" e-fan on yesterday...so I was thinking it might be my thermostat. Like seriously, 6 donuts and the car was ON FIRE...
reps.
collink
Post by collink »
LOL....
Okay, seriously...rough weekend...my water pump 'SPLODED yesterday, put some dents in my hood, cut some MAF wires, wrecked my 3-month old all-aluminum radiator...now I think my thermostat's bad.
Does my reasoning sound viable?
replace it. its only like $12.
probably air bubbles in the system.
P.Haire wrote:probably air bubbles in the system.
yup. pockets of superheated air causing that gauge to go apeshit and then add in the fact that a waterpump can't move air..
i say do both. bleed the air out and change thermostat. if that dosent work insert dynomite into car
collink
Post by collink »
Ooooh....dynamite...that's a good idea.
It looked like someone had slapped some C4 on my water pump yesterday. Like, I don't know WHAT the fuck happened....but 4 of the 5 bolts were still there, and chunks of the water pump were as well...
It was the most gnarly failure of a piece of equipment on a motor vehicle I'VE ever witnessed....
malone
Post by malone »
did you replaced the radiator as well? if so, how did you go about refilling the coolant system?
btw, i seem to recall telling you a few months ago that you would fuck it up... :lol: i was right...
me-"officer, my yellow headlights just dwarfed your spot lights. i can see fine"
officer mouth breather "well... they're just so damn annoying"
me- "so... you're going to write me a ticket because my headlights annoyed you?"
are you fucking serious?!?!?!
Sounds like you don't need to work on your car. Repz.
malone
Post by malone »
struka wrote:Sounds like you don't need to work on your car. Repz.
he doesn't... he's still kind of a grasshopper (no offense, nazi)
collink
Post by collink »
I'm going to bleed the coolant system tonight. Will report after that.
skylinesx
Post by skylinesx »
yuuup just let all the air bleed out and might as well replace the thermostat before doing that b/c you'll have to bleed the system again anyhow when you replace it.
1991 nissan 240sx
-1995 nissan pathfinder
