Excessive Drift Mileage?
Analog Odometers
Digital Odometers
After giving this some thought... I'm wondering:
If mileage is based on a ratio of drivetrain rotations/wheel rotations, etc... in theory then...
wouldn't you be putting MORE mileage on your car by drifting than what is the car is actually being driven as such?
Any thoughts?
Yes. Which would mean that your car only has about 50k versus the indicated 90k+.
BTW where did this come from? You've gone without sleep for a week again haven't you? :D
Hahaha... I got no sleep last night... but I slept all day yesterday - so I'm not totally drained!
I started thinking about this at RS*R. I watched my mileage at the event, and at the end of the day, I had driven 15 miles. I thought... there's no way I drove that much. Granted, I had a TON of runs... but I didn't travel 15 miles worth.
The more I thought about it... the more it made sense that my wheels rotated enough to travel that far... but the car didn't run on 15 miles worth of asphalt.
hmmm....very interesting thoughts. sounds like it could indeed be correct.
MasterMadman
Post by MasterMadman »
Indeed, I also agree that this could be possible.
AadosX
Post by AadosX »
It's definitely correct... but it's not like you're getting ripped off or anything. ;) Drifting puts a lot of stress on a car haha. I mean, what is milage exactly?.. and why does it matter to you/most? :idea:
Prince Nismo
Post by Prince Nismo »
it's ok i can drift all day long b/c my speedometer doesn't work so i haven't really driven a mile since i bought my car. i guess thats the advantage of having no speed sensor.
Drift long
Shift Short
Boost High
Ride low
turbofb
Post by turbofb »
depending on where your car picks up a wheel speed signal from, if it is picked up in the rear then you will add more miles to your odometer when drifting. But if taken from a front then it would be the same as regular driving. Older cars like mine pick up a analog signal/cable from the output shaft of the transmission, so i would add miles to the odometer. You could unhook your signal, but it might go into a limp home mode, or set a code.
K-groove
Post by K-groove »
turbofb wrote:You could unhook your signal, but it might go into a limp home mode, or set a code.
That may be slightly illegal, but who am I to talk.
turbofb
Post by turbofb »
so is drifting on the street
CubanMike
Post by CubanMike »
DRIFTING IS NOT A CRIME!
And neither is disconnecting your odometer!
Grease Munkey Drift & Speed
GreaseMunkeyFC@yahoo.com
bavdrftr318
Post by bavdrftr318 »
Haha VERYYY intresting thought!
1997 BMW 318i
columbo
Post by columbo »
HA!!! ive never thought about that b4..... thats very true.
